hole in water pump
bzizzi
10:43 PM
connecticut
I just bought a new impeller for my 69 roadrunner 383 water pump. the impeller housing has a 12-24 threaded hole at the 6 o-clock position. grease fittings don't fit. what is this hole for? If it was a bleed hole, why would they thread it? should I plug it or leave it open?
blake
That would be a weep hole if the mechanical seal goes bad it leaks coolant there not shout why it is threaded
Thank you guys. I put it back in the car without plugging the hole.
