70chall440
- 1:51 AM
- Feb 11, 2018
- Yelm, Washington
As I am building my 71 Charger I have decided that I want to use a Holley single plan intake, mainly because it will allow me to run a Mopar oval air cleaner under my air grabber.
The first issue I am encountering is that it does not seem that anyone makes an adapter for a Mopar throttle body to a 4150 intake. Everything I can find is for an LS, specifically a drive by wire (DBW) LS3 type. I have the harness for my stock DBW Mopar TB, not sure if that will transfer over to a LS one or not, but I am thinking that I might just machine an adapter so I can keep the Mopar TB.
This brings me to the issue of the sensors; I believe that the TB takes care of the TPS internally, however I still will need to address the MAP and I think the IAC. I can probably mount the IAC in the air cleaner as I have done previously on my EFI Cuda and Challenger and I see that there are external 1 bar MAP sensors so I guess I could use one of them.
Looking for comments, suggestions, information, etc.
