Horn is constantly on. Need Help!!
If the horn blows when you fit the s/wheel, then it sounds like the wheel is pushing on the switch, which is sounding the horn.
Also I tested the brass horn stud on the turn signal assembly and am getting 12v constantly. The steering column is properly grounded. Still at a loss here for what going on. The horn button plate on the steering wheel is fairly new. I got it new when I ordered the wood steering wheel a few years ago. Also the copper ring on the neck of the steering wheel looks good. I checked the rubber between the copper and the wheel and it looked good. I should have known better to re-wire this car myself, here we go with all the little issues.
If you are saying you have 12v on the brass roller. That shouldn't be hot. The horn button completes circuit by making ground. It's gonna be something simple I can relate to the frustration though.:thumbsup:
The switch is on top of the wheel and nothing is pushing down on it when installing the wheel.
You say you installed a new wiring harness! If the horn worked properly before, and you made no changes to the horn, I would look to the harness as a potential source.
I have an issue, the horn sounds when I touch the steering wheel, and of course when I push the horn buttom, I think thats makes ground when I touch the steering wheel
What I need to check??
Thank you
Hello. I send you a DM but your inbox is full
Can you solve the horn problem??
I would first put an ohm meter on the brass ring and steel splined area and see if it’s actually making contact.
I’m not sure where to buy a new one of those insulators. I had one I stole off of an old steering wheel.
Also if you do change it be sure to mark where that signal canceling rod is and put it back the same or your canceling will not work right.
Hello 70Hemi-RR
This plastic bushing its like this?:
Fits A-Body B-Body E-Body C-Body Dodge Truck Steering Column Bearing Insulator
Thanks in advance
No it’s a thin plastic insulator on the steering wheel itself. I don’t have a picture.
