Yeah, I calculated the same change in spring pressure which worried me since Hughes likes stiffer springs. I bought the cam, lifter, spring, oil package from them for their "No flat cam guarantee" and am following their instructions, all 13 pages.
I removed the seal and the cup was shimmed. Removed the shim and remeasured - 1.875". Also checked the mic and it's good within my measuring capabilities +/- .001
Based on this and measuring the shim, I think my original measurements are also off at least .005. I don’t think I had the gauge tight enough to put sufficient seat pressure on the valve.
I need to measure the rest of them but the guidance here is to have no less than 1.88-1.9. The only solution I have found so far, short of more machine work which I'd like to avoid, is to go with +.100 retainers and locks then shim back down.
