johns
It usually tries to fires as you let off the starter but eventually starts and runs perfect. Tested the bat feed and ign source to the ignition box and both show 12V until you start cranking and then drop to 9.9V which I don't think is uncommon. Next step is to test the spark while cranking it at the cyl.
Ignition key switch maybe when swapping from the cranking to run position at fault?
