how to measure a 11 inch flywheel
moparjohnny
2:28 AM
ga
i want to know how to measure a flywheel to make sure it is 11 inch,it has 143 tooth,but where do you put tape measure on wheel to get 11 inches? thanks
I would presume you are looking for an 11" disc diameter which would be well inside the bolt circle. If it wasn't machined you should see the wear pattern from the 11" disc.
I believe Mopar 143 tooth flywheels are normally used with an 11" clutch setup. The 130 tooth can run the 10-1/2" or 11" scalloped clutch setup with the correct bell housing.
