I Broke it!
Cncguy1
8:27 PM
Gosport, Indiana
Well, today I decided I'd drive my 69 Charger to work, its an hour drive one way. All was good cruising at 75 80 then as I approached a construction zone I down shifted, and the Charger went into a massive vibrating fit. The vibration seem to be more calm at 55mph so I limped the rest of the way to work then straight back home. I have not had a chance to inspect but I'm suspecting U Joints. What do you guys think it is?
I’d check the lug nuts first then jack it up and check the drive line.
If it happened on a downshift (throttle transition), check all your motor and trans mounts as well. U-joints are a "reproduceable" vibration in my experience - EVERY time you hit a certain MPH, they will act up. Is that the case here? Or is it accel/decel based (i.e. motor sitting differently in the mounts)?
Sounds like you should take a look first, and then you'll know!
The transmission is toast. Likely blew the johnson rod right through the encabulator so it's gonna have to come out for a total rebuild. Perfect time to upgrade to a full manual valve body and billet titanium internals.
This vibration was at any speed, like I had 20 inch kicker speakers in the trunk. 55mph was the only speed that it was tolerable no more no less.
I hope it's not the drawn reciprocation dingle arm. The sperving bearings and marzalcoptic vanes would need to be replaced as well.
There's no way I could have driven it home after limping it on into work! If it was just a muffler bearing, yeah, that would be ok to do and usually a muffler bearing will let you know that it's bad. Let us know what you find.....
