Mike Miller
I have a 74 charger and just replaced all of the wheel cylinders, calipers ,and master cylinder.. the old system was contaminated after years of sitting unused. Having done this many times back in the 70s and 80s this is not my first. Bench bled the master, had to make a new feed line for the front going into the proportioning valve. Bled system over and over ..pedal went to the floor. Thinking new m/c was faulty i pulled it and replaced yet again with a new one.. same results. No air coming from all 4 bleeders, used vacuum pump, old school 2 person method.. same thing. Short fast pumps will build pressure, than right to floor again. No fluid leaking anywhere.. cant build pressure to bleed correctly.. bled fronts at hose connections, no air.. any suggestions ?? Thanks..
Mike
Mike
