I think I found a little gem
furious70
8:12 PM
Chicagoland
It's for a 74, and I need the switches and wiring harness (or make my own), but will greatly improve what you see when sitting in the car (has the standard sweep dash)
My 72 is a clone, but has the RR grill. I have a 72 440 for it, and the stuff to convert to buckets and console shift.
You can extend the headlight wires and move the plastic connector housing.
Biggest issue is the rallye cluster uses individually powered/wired bulbs and the sweep cluster is all through the pins.
I have now found a harness from a 72, seems to line up mostly, but was a clock not a tach.
Snagged the wiper switch that was posted here as well. I'll pm you in case your harness is a perfect match
