- 12:45 AM
- Jan 15, 2020
- Okeechobee, Florida
I finally came to the realization that if I tried to cut corners, I would just double or triple the problems and costs. With my current project (and last one I hope) a 1963 Plymouth Savoy (my old race car MAXIMVS) everything I did was at least 20 years old. The man I sold it to did a great job of preserving my work but time is unforgiving and nothing is going to stop aging - I know, I'm 65 years old and can attest to the fact that I'm not the man that I was 20 years ago.
That said, do yourselves a favor and realize that when you take on a project, that little will be able to be saved. Just resign yourself to commit to replace EVERYTHING, as it will need replacing.
I committed to return MAXIMVS to street duty and that means that ALL the fiberglass body parts would have to replaced with OEM steel parts - hood, deck lid, bumpers (the bumpers have been replaced with new AMD reproductions - $1300 but worth it IMO).
I've had to replace the following that I thought I would not have to replace:
Chuck (snook)
- All front end components and I mean ALL. Bushings, spindles, bearings, torsion bars, shocks, etc, etc.
- Front and rear disc brake systems including hoses, calipers, rotors, master cylinder, spindles, etc, etc.
- Trans work - the rear support was shot so I had the whole trans gone through. Seals were shot, gaskets were shot. Thankfully, the RMVB A&A VB was OK. I had to go a less radical PTC 9.5" converter for some reasonable street manners.
- Engine work - the heads needed work, new guides, decking, etc, etc... New solid ISKY roller and EZ roller bushed lifters with spring kit (retainers, springs, keepers, etc, etc...)
- New carbs modified for Max Wedge crossram use (too long to get into this, so I'm going to leave it at that)
- There's more but I'm sure that you get the idea by now.
Chuck (snook)
