- 10:23 PM
- Oct 16, 2014
- Salisbury, Vermont
Help me out here.... what the F88K are these brackets? Thanks..
Which middle one? Number them from left to right....The middle one is a vent widow bracket that is inside the door.
I thought the left one might be a frame mounted bracket for a brake line hose?Left one look like the bracket that bolts to the ear in the tranny and is part of the shift linkage would normally have a Nylon bushings.
This used to be a column shift too...I asked the same question when I removed mine, it was bolted to the driver's frame rail near the firewall. The answer I got then was it had something to do with the column shift (mine had been long-converted to floor shift).
