ID'ing a motor
moparsquid
8:40 PM
spring valley ,ca.
hello i just picked up a 67 440 hp its date coded at 10-66 im trying to id the car it came from i thought the vin was stamped on the bottom of the block pass side but i dont see it does the 67 hp have one?
thats what i figured was thinking i could match it up if the owner wanted to make it original
Your top pad should have C 440 HP and a engine build date.
yes top says c440 bottom 2 8 hp
That engine was built February 8, 1967 so it is a real 67 440 HP the cast date on the block will be prior to the engine build date by a couple months or more. 10 66 is not a stretch.
