I'm getting some weird reactions when I try to post pictures in threads.
Kern Dog
Life is full of turns. Build your car to handle.
9:30 AM
Granite Bay CA
I'm not sure what is going on.
Earlier in the day, I was out in the shop and when I tried to post about the progress of a project, I'd click on a picture to use, it would show it loading on the screen but stop at a gray box like so:
The pictures are actually there but there isn't a way to get them to display onscreen. I thought it was an issue with the phone but I'm getting the same thing here on my laptop.
When I post on the forum, I often have pictures, text, more pictures and more text. It is the way that helps tell a story.
Does anyone else have this problem?
@Cranky @kiwigtx @HawkRod @DeltaV ??
The truck forum is working but for me, FBBO and FABO have the glitch.
This is how pictures normally look before and after I click on them:
It is still messed up here.
There are members on C bodies that can't post on threads. Works fine for me. Joey is working on both issues. It's probably pretty tough to find issues that only effect certain members. It may be a software issue but it is probably caused by something on your end.
Okay, thank you.
If I were the only one that encountered it, I would think it is a problem with my own stuff here.
just a test! MEH, I hope this works?
Update , Yup ! No problem .
I'm not sure if others are having the same issue.
To repeat, The "Add Photos" box is at the lower left. I click on that and it takes me to my files that are on my laptop. I click on a picture that I want and usually, the picture loads and appears in the lower left corner in a "thumbnail" size. You then have the option to leave it as a thumbnail or enlarge it. You make a choice and then it appears on the page. You can usually write words, insert a picture, write more and insert another picture.
That last part isn't working because the pictures that I clicked on only appear as a gray box with nowhere to click to see the image or enlarge it. The gray boxes do show that something is there but I have to click "Post Reply" in the lower right corner to get it to appear.
That's goofy how that works for you.
How about "insert image" in the options above the text?
I get the "OOPS, we ran into some problems" response.
EDIT:
After I hit REPLY, the image actually comes up.
I've had the gray box show up, I click the delete trash can and try again. Usually works the second time
They aren't all naked. My current thing is toned and flat stomachs!
Also, I can't copy and paste any pictures.
Hey, if you guys wanted me to cut back on posting memes, I'm sure we can work something out another way!
C bodies is having some similar issues and the Tech people are working on it. Please be patient.
I know almost nothing about the functionality of software so yeah, I appreciate that it may take time.
Thank you.
