In Tank fuel pump 64 belvedere
64plymouth
3:09 AM
Wisconsin
I need replace fuel tank in my 64. The current set up stock tank with weld in sump -8 line to Holley black pump with return line back to tank. I would like an in tank pump. Does anyone make something bolt in for a 64 b-body? Thanks
I’m definitely keeping an eye on this. Hoping it ends up being a really straightforward install for you
I just installed the Aeromotive 18463 tank (bigger pump than 18163) in the 65 belvedere last night. Same part number on the old (10 years?) one as on theirs. There was already foam above my tank, so I just slapped it in, fit fine- no shimming. Hope to finish the plumbing/wiring by tomorrow....nice hardware!....
I mentioned to Bret a couple weeks ago that that part number should fit more than the Polara, at least when you look at what the Dorman part # fits for the 64-65 Polara. Spectra doesn't make it easy to cross.
I just looked up 64 dodge & Plymouth on Rock Auto same part#. Good to hear install was straight forward.
