installing the rear disc brake kit from SPEEDWAY MOTORS
red340bbody
2:46 AM
Hamilton
:headbang:i BOUGHT THE speedway motors REAR DISC BRAKE KIT .
This kit was meant for a ford passenger car BUT i had a friend make me the proper plates that bolt to the rear axle flange .I ordered a caliper from a 1989 trans am with the built in e -brake system . I put it all together after i filed the rotors flange so i will slide over the axle flange .I have had to modify a couple of things to make this set up work and it has been pretty easy .the last thing i went to do was put on the caliper pins and tighten it up and it was good to go .well i put the pin in tightened them, up to spec and go to spin the rotor NO SPIN ......I have to machine a spot on the caliper pin near the middle of the pin as thick as the rotor and them it will be good to go . the e -brake will be the next thing which i will be using the factory 1971-74 charger rear e -cables and center cable so it will look factory in a sense if so one happens to take a boo under neath... hope to have pics soon ...
Please post up more and pictures Sounds like it was reasonable priced project
the rear bracket kit from speedway is 100.00 .it is meant for a FORD car .I made a program and have had to make the proper plates that bolt to the axle housings . I sell these plates that mount on the axle flange then the caliper plates bolt to it . You do have to use the new style bearings (sealed). I did use something of difference from the norm. They say (SPEEDWAY MOTORS) say to use 1978 -83 cadilliac seville rear calipers......Good luck finding a set of these i will provide all in detail of parts from start to finish once I am finished . Any questions about the brakets that i make please message me ....I will only make these plates for the FORUM MEMBERS only and at a price that you cannot make them yourself any cheaper . It is the way of me i have to improvise to make things happen , I look forward to hearing back from members to see what they think of this ....
