Installing V8 in a 6 Cyl car
Mason66
12:10 AM
Mexico
Is it possible to install a V8 in a 6 Cyl car without changing the K member?
Are there any parts out there that help with this?
Thanks
Schumacher does NOT have a kit for 62-65 B body cars. I checked. Unless you want to use a motor plate, you will need to swap K frames.
-Matt
Yes, but as Badvert65 posted you will need to swap K-frames or have your K-frame redone.
Also like douggreif posted there is a large amount of information on this subject if you use the search option. Good luck with the swap, Al
K frame swap is the best way if it's going to be a driver. The good thing is there are tons of them out there and all v-8 k frames are the same for 63-65 regardless of engine size (Hemi excluded).
