Ray Lawrence
Do I have to take the steering column off to remove the instrument panel on a 73 roadrunner?
New a tach is any one know where there's one.
Its easier when the steering column is not in the way, however, you can loosen the 3 column retaining bolts on the bottom of the column, which will allow it to drop down, also you may want to remove the steering wheel, that helps to get the cluster out once the column is lowered a bit.
