intake
charger1
New Member
7:01 PM
Bradford,ontario,canada
hi everybody just a question i have a 77 charger se 360 ci 2bbl that i am changeing to a 4bbl but i have a egr valve on the original intake can i use a non egr intake ?if so what do i do with the egr and hose that goes to it ????? any feed back would be great thanks:yes:
Typically engines with EGR's are set up to run leaner and simply unplugging it may make it ping, but since you are changing the carb and intake then just plug the hose or take out the system completely. There may be a thermo switch and a vacuum amplifier involved in the plumbing. Some of these can get pretty complex.
Edelbrock makes an Performer EGR intake that could solve your need for power and keep it simple.
