Is 68,69,70 side glass the same
dart6
8:20 AM
Auckland
Hi a friend had all the glass apart from front rear windscreens swiped off his 68 Satellite Coupe by some scum
Is the door and rear quarter glass the same for those years as i know the windscreens are
Will be wanting to source a set too. I will list in the WTB when i have the info
Cheers Brett
it is either roll up rear side glass for a hardtop
or pop out side glass for a coupe
coupe and hard top door glass is different also
door shells are the same for both
the years will interchange
I'll check on those rears, i wasn't aware of that
a coupe is also known as a post car
and it will have a metal post in between the door and rear pop out window.
a hard top will roll up and down and will have nothing but a seal in between the door and rear roll up window.
so if you are calling it a satellite coupe
it would have the post and pop out rear windows with that specific door glass.
any year of that specific set up would work
Cheers for that, good info
Cheers Brett
69 and 70 door glass are the same. 68 use a different up stop, so don't have a hole in the lower rear corner. You can put 69-70 door glass in a 68 but not 68 in a 69-70
The quarter glass is different between Dodge and Plymouth.
Any 68-70 B body quarter glass should fit as long as it is from a Plymouth
