Is a 383 k member the same as a small block?
Should be same for those years.
If your question is will the 383 bolt to the small block K frame.....the answer is yes but you have to use the big block motor mount brackets. Unlike the small block, all the big block brackets are the same for those years (except for the Hemi) and will drop into the small block K frame. The stock Hemi K frame is a different animal.
