krowbar
Checked spark plugs and looks lean. I'm thinking of jetting the carb up and don't know if I should do all 4 or just the primaries. This is my setup.... Holley 850. No choke.with 80 jets front and back. Recent rebuild on carb new pumps,new baseplate,new 6.5 power valves new primary float.new open air cleaner assembly(had dual snorkel) 1/2" phenolic spacer. Idle mix screws about 1 3/4 out. Timing about 20° initial. Fixed overheating issue with new stat and radiator. Runs about 190°. Idles good. Runs good,except for a little flat spot past idle. All this on my 440 w/727.
