K-frame bushing bolts
moparman73
6:00 AM
Upstate South Carolina
Just installed new energy suspension polygraphite bushings to mount my newly painted K-frame to the 73 Charger.
Does anyone know the torque specs for the four bolts that hold the K-frame to the body? Also if anyone has a link to a PDF copy of the Factory service manual it would really be appreciated!
They should be 50 ft/lbs.
You should be able to get a factory service manual from ebay for like $30. They send them on a CD as a PDF.
50ft lbs? I think I torqued mine to about 125 with red grade A locktite on them. Don't want that bad boy wobbling around in there but I have solid mounts too
I bought a K-frame bushing set for my 73 Satty, I was wondering if when you guys got yours could you get the bolts and all? I got mine thru Year-One but they said i had to use my original hardware... Im hoping i can use them with no problem but it would be good to know i can get them if i do need them... Thanks..
Thanks you guys, I really hope mine will suffice but im glad to know you can get them!
