- 12:16 AM
- Jul 9, 2019
- Modesto California
For it to drive as poorly as you indicate something isn't right.... You say stock but clearly it has later discs which have the spindles swapped side to side to clear the early sway bar.... That should all work together without issue but it's not technically "stock"...Hi Guys,
I was wondering if you can point me in the right direction.
I really hate the way my 69 charger handles. I would like it to be more stable and predictable for normal driving on the street. Terrible bump steer and the car really leans when turning.
On the freeway, it drives like a dream as long as you don't hit bumps or have to turn slightly. Let go of the wheel and it stays true.
The previous owner rebuilt the entire (stock) front end. It also has sway bars front and rear. New rear leafs too. The front end has been aligned.
I would rather not do a full front end suspension change (QA1 or similar) and would rather just change whatever helps me to get somewhat better street handling.
I have been searching but I can't seem to find a forum topic that can help me.
Thank you in advance.
Hard to tell in the picture but what is the sway bar diameter? it looks kinda small which your leaning in the turns tends to confirm...
Also what shocks are those? any idea what the numbers are from the last alignment?
You say it's been aligned but by who? Joe down at Big O tires or Bob at Goodyear turn the adjustment to what their computer screen tells them... That's not how you make these old cars handle... Ask around & find a shop that knows performance handling.. Expect to pay a little more but expect to get a little more too...
Wish you were closer, making these cars driver well is something I like...
