Lca bushing sleeve
Ralph c
9:26 AM
Indiana
Are 71-72 Plymouth roadrunner lower control arm bushing inner sleeves,are they the same on 73-74 Plymouth roadrunner,and where can I find them??? Thanks for any info
I don't know of anywhere you can buy those individually. If you are putting in eurothane bushings that came with out sleeves ,you usually have to reuse your old sleeves.You can usually melt the old rubber out with a torch and polish them up on a wire wheel.
They are two different number bushings though not sure the actual difference but there must be...
Moog K791 for up to 72 bbody
Moog K7059 for 73-79 bbody
As mentioned you likely can not buy just the sleeves
