Leaf spring bushing removal help
Moparguy1
1:18 PM
West Virginia
I have a set of super stock leaf springs that I am trying to remove the old rubber bushings from to install new ones. What is the best way to remove the old ones? I don't really want to burn them out if I can keep from it. I have sprayed them with PB Blaster and hammered on them and they have not budged. Any help would be appreciated.
Yes, the front eye bushings. I have a press but it is not at my house, it is in storage due to not having the room at home for it. I might be able to use a small press though if that will work.
Well I got one of them out but do I need to remove the metal piece that is between the rubber and the spring it self?
You likely need to get it out. What bushings are you installing?
I take a chisel, fold the sleeve in on itself and it will fall out or can be pulled out easily.
I bought a set of poly bushings from Mancini Racing but I am not sure of the brand. Thank you all for the help.
If the bushing doesn't have the sleeve on the outside, leave the one in the spring eye. The urethane one should slide inside the oem sleeve.
