Leak on a four speed
71RRHI
1:25 AM
Hawaii
This is my first four speed. There is a leak from this plug under the neutral switch. What is this plug for? Can I remove it and replace the gasket?
Yes you can replace the gaskets contact Brewers transmission for the parts, That part is for the reverse gear lever it has a spring an a ball bearing in side so be mindful when removing it.
That is not a neutral switch. It is your back up light switch. Make sure its not leaking from that. I have seen way more switch leaks than the reverse detent leaks.
Looking more closely it does appear to be leaking from the back up switch. Not from the threads but the switch. Looks like a newer switch. Possible cheap china repop. Any recommendations on where to get a new switch. I know Eric Pearson recommend Brewers.
