More than likely if you just do the tail lights you probably won’t need the LED flashers. The more LEDs you add such as turn signals and brake lights then you will need the LED flashers. You will know when to add flashers when the LED quit working.No LED flasher needed everything works great
AGREED ! I used LED bulbs in the rear and the front turn signals are the halos around the headlights. The 57-year old flashers work just fine - in fact, LED flashers didn't work AT ALL - and I tried three different ones !! HOWEVER, LEDs are "polarity specific" so you "may" have to flip the terminals in the flasher connectors.No LED flasher needed everything works great.
How would they fit in a 68 GTX ??I have digitails in mine and the sequential part is great.
Thank youIve only used led light bulbs. They were good. But one side looked brighter than the other. Maybe it was a ground issue. For the money id say they're worth it.
You're welcomeThank you
what brand? thanksYes I have led,s make sure you use a led flasher with the ground wire for turn signal and 4 way flasher .I tried the ones with out the ground wire and had trouble.View attachment 2008757
Go hereThese are very well-built not cheaply done I did a lot of research when I did this but I just don't know where the boxes are to tell you who the maker is sorry possibly super bright LED is the website you could check out I know I was really interested at that site
