Lift off hood & door hinge questions Help!
Clay Dots
4:17 AM
Boise ID.
Hey I was wondering if anyone has had any expeirence (fit,quality etc)with the MAS fiberglass lift of/ six pack hoods. I have heard good and bad so I dont know. That company went out of business but there supplier is still making them and seem to be a reasonable priced option to the 6-7 hundred doller hoods. Anyone ?? Also I need a new hinge for my 1969 project as after much frustration not getting the door and front fender to not rub only to discover someone had put a passenger door hing in place of a driver door hinge. So I ordered a driver side one off e-bay and the guy sent me another passenger door hinge :mad: he said they look the same to me, yep they do only one has the pin going up and one going down. Does any one know if I take out the pin and put it i going the other way will this work? Or any body have an extra hinge out there in b-body land the one in the pic is the one I need? :yes: Thanks for reading my post!
They are the same hinge flipped side to side. A trick to "fix" a sagging drivers door is to get the top hinge from a passenger's door and use it.
Done it several times..............
Thanks does this work ?
My body guy has not been able to get the door and fender adjusted so they dont rub togeather with the one that is on there that I just put new pins and bushings in. Before the rebuilding of the hinges it was sagging majorly with the passanger side hinge. Maybe the e-bay p-side hinge I just picked up would work better than the one I rebuilt? Thanks for you help.! :yes:
Possibly.....if your original didn't get drilled straight
Thank you for your help
:yes:I appreciate your insite,in looking I think its possbile the one that was on there we rebuild might have came off another body style like a-body or something. we are going to try using the new/used/e-bay purchase p side one and see how that works.
Best wishes!
AAR Fiberglass in Cocoa,Fl has a good product, I have a lift off and SS hood scoop on my 65
