Lights on but wont crank
Snowbug778
10:25 AM
Glendale
So we stuck a neutral safety switch in my 71 charger and now all the lights come on but the car wont start or even crank, any ideas??
1)Will it crank if you jump the starter( car in park, foot on brake) 2) Does the neutral safety switch have a good ground. 3) Is the wire from the transmission grounded when in park and neutral. 4)Is the wire from the ignition switch hot when turned to start.
It might be the nss we found a fix for now!! So she runs atleast
Did you get the correct nss for your year transmission? They will all screw into the housing but the wrong ones won't match up to the the rooster comb.
