NHCharger
- 10:52 AM
- Jan 27, 2011
- Northeast Rust Belt
Been having a problem with my 440 since it was built. I pulled it this weekend and just removed the timing cover.
According to a video I watched on youtube, Pete's Garage-Cam install it shows the timing dot on the cam gear at 6 O'clock, pointing straight down towards the gear on the crank shaft.
The gear on the crank has two zero's on it. The one on the inside over the keyway and the outer zero near the teeth. According to the video the inside zero should be pointed towards #1 cylinder and the zero close to the teeth lining up with do on the cam gear..
This is what I have.
