Lokar ED-5026 and six quart pan - 383
wasco
5:55 AM
Spokane, WA
I have a six quart oil pan on a 383 with headers and high volume oil pump. I’m changing the oil and only 3.5 quarts came out, including most of what was in the filter. I filled the new filter part way before installing (1/3 quart), then put five quarts of oil into the engine. I ran it a few minutes and checked the dipstick - it indicates about 1/8” over “full”? Shouldn’t it need another quart? The Lokar is correctly installed into the block. Oil filter is Napa Gold 1515.
But the dipstick goes into the block - shouldn’t it read correctly regardless the capacity of the pan?
You would think so.
Bottom line is you want 6 quarts in there so when you fill it and run it once wherever it shows up on the stick on a level surface is the desired fill level.
What pan is it?
I’ll have to go back through my receipts - I think I got it at Jegs or Summit, just a bare metal six quart pan for big block Chrysler.
