FOUND Looking for 71 to 74 B body or e body shifter mounting plate.
chargervert
3:20 AM
Rhode Island
Feedback: +11 / =0 / -0
I am putting my 71 Charger together and the shifter mounting plate I have is not the correct one. It fits the front mounting bosses for the shifter on the tail shaft but doesn't fit the rearward mounting bosses that would mount the pistol grip shifter in the 71 to 74 B body or E body shifter mounting location. If anyone has the right one I will buy it or trade the correct one to mount the shifter in the 66 to 70 B body shifter location. Thanks Pete.
This is the incorrect one that I have. The E body/71 to 74 plate will look similar, but is larger.
There are two different ones-
Bench/Buckets and buddy seat.
Buckets and console/buckets with nothing.
...and they take different rods.
That is the bench seat bracket for the longer handle pistol grip shifter used in 71 to 74 b body cars. The one I need is for the short E body and 71 to 74 B body shifter that is mounted on the end of the tail shaft housing. The one you have mounts the the forward mounting bosses on the tail shaft housing. The one I am looking for looks like the aluminum one I posted but is slightly larger.
I thought I had the right one when I bought the shifter as a complete assembly, but the bracket is for a forward mounted 66 to 70 B body shifter. The mounting plate in this picture is not correct for this shifter.
Just FYI- the bench/buckets and buddy mount also mounts to the rear pad.
