Looking for a good brand of trans pan gasket?
Jimmy Van Hoose
5:01 PM
USA
Putting a new pan on my 74 Satellite with a 727 and want a good gasket to go on it. What are you guys using? Anyone trying the ones with metal in them? Thanks.
silicone
ebay
$38
Stay away from any aftermarket stamped steel pan. They are too thin and will deform when you tighten the bolts. Use either an original Chrysler or an aftermarket aluminum pan and a cork gasket. Torque the bolts to the correct spec. Those steel reinforced reuasable and "O- ring" gaskets might work well, but you don't need to spend the money.
