FOUND Looking for Max Wedge air cleaner(s).
Kramers and mancini both sell reproduction sets made of steel. There used to be fiberglass repops, but i think they disappeared after steel became available.
What carbs are you trying to use? The early max carbs had a smaller a/c mounting ring than the later carbs (or edelbrocks) Kramer has both, mancini just the later style.
Mancini's are marked down to.$400, kramers a little more.
My guess is, if you could.find some real original ones, the would cost a LOT more than the repops.
Thank you for the information. I actually have three of the fiberglass ones but was unsure if I wanted to go that route or not. As far as carbs, I would like to go with modern Edelbrock. Again, thanks for the information. I am going to check Mancini's now.
I have a set of 3705 bases I'll be getting rid of soon if you need them.
