Looking into getting wilwood fronts..need help
68.mopar
11:57 AM
montreal quebec
Hi guys,
Looking into wilwood fronts (link below) for my 1968 coronet.
It currently has front disc brakes. I bought the car like that so I'm not sure if it's factory or aftermarket?
Reason why I thought I'd ask here before purchasing on summit because I read on their site that it's for models for front drum spindles?
Shouldn't make a difference?
Link:
https://m.summitracing.com/parts/wil-140-9828-dr
Don't know if they make a model for disc spindles. I've always gone from drum to disc. Unless you're looking for weight reduction or bling....I'd go cheaper and more readily available stuff. I've got a set of wilwoods, that won't quit squealing. First time for this issue.
Hi guys,
Link:
Give Dr. Diff a call, his kits are top notch for Mopars. Seriously I've had the others, they don't even come close.
Yes, some of wilwoods models are for front drum spindles which is a great aspect of their kits versus others that require disc spindles.
Thanks guys
But did the 68 coronet come with disc brakes from factory or they were all drum?
