loose lug nuts!!!!!
hemi#1
5:22 AM
pilot point tx
I took my 65 satellite to an O'reillys grand opening today just a short drive to get the bugs out. going there was great but going back was a whole different story!! the car started clunking and I'm within 500' of the shop and the right front wheel came loose!!! luckily no damage to the car!!! I'm NOT a fan of unilug wheels. I messed my pants being the first time in 45 yrs. of restoring that it happened next time out the wheels will be torqued to 100 FT. # plus :oops::angryfire::angryfire: I guess you learn from your mistakes thank god I was only going @ 20 mph.
Ya got lucky for sure. Don't beat yourself up too much, we all make mistakes. Last year I over torqued my valve covers and they pissed oil all over the engine compartment and smoked me out. It happens.
I learned many moons ago, with mag wheels, to tighten them down, take the car for a drive, then re-torque. Works every time. They will work loose if you don't.
I may use blue lock tight on them if you want to take the wheel off later use a propane torch to break the lock tight loose
Yikes! that's never a fun time. Glad there was no damage to the car.
There was/is a problem with this in the trailer industry with some manufacturers. All trailers, flatbed, garden, cargo, cattle/horse, R.V.'s, etc. The steps to ensure they hold torque is to:
1. Make sure the hub face and back of the wheel is clean. NO rust, dirt, grease or paint of any kind on the contact surface of the hub or wheel.
2. A couple drops of light oil on each stud, install the wheel, torque to 90 Ft. lbs using a "Star Pattern" tightening sequence. Always re-touque the first and second nut in the series.
3. Drive the car a short distance, 5-10 miles. Make sure you make some left and right turns as you normally would.
4. Re torque at 100 ft.lbs. using the "Star Pattern" and hitting #1 and #2 nuts again in the series.
5. Put about 25-50 miles on the car. Recheck at 100 Ft. Lbs. You should have no torque loss. If you do, re torque and repeat step 4 and 5.
6. After the 3rd torque your wheel should be "seated". if you still have torque loss, your wheels are flexing and should be replaced. It does happen.
We use this basic process at work and I haven't had a torque failure wheel loss in 8 years after Hundreds of thousands of trailers.
You didn't say, Steel or Mags? Mags generally hold torque better because they don't flex (much at all) at the clamp point. Stock steel wheels will and do flex and should. that's what holds the torque. I actually crushed the center on one on my stock '64 and had to replace it. Now I run Centerlines because after the power upgrades, the steelies wouldn't have been safe.
Lastly, (i'm sure you do) use a torque wrench. I can't tell you how many times I've caught transport drivers in our ship yard reefing on lugs with a 4' breaker bar. Needless to say they get the long version lecture whether they like it or not.
X3 on re torque after a short drive and then every once in a while for peace of mind.
I always use a torque wrench on wheel nuts
I also retorque nuts on motor home before a long trip 475LB,s 6 sets of 10
I also bought my daughters torque wrenches and showed them how to use them
We just have different loose nuts in my family
I had a front wheel come lose on my 63 Plymouth one night, bad thing was I was on the return road at our track and had just been 144MPH :(
Back about 1970, I took my 1968 Roadrunner to the Chrysler/Plymouth dealer for service. After getting home, I noticed that one wheel only had 2 lug nuts installed. Fortunately nothing happened.
