Low Brake Pressure Switch?
dodge68charger
7:22 PM
Washington
Hey Guys Just Wondering If Anyone Makes A Switch I Can Plumb Into My Brake Syestem That Will Activate a Warning Light On The Dash If The Pressure In The Brake System Drops..
Using An American Autowire Harness and My distribution Block Didnt Come With a Wiring Provision
Cars a 69 Road Runner But Not Stock
Does your car not have the "Brake Warning" light on the dash?
The front and rear brakes supposed to be separate circuits, in case of a hose burst or other leakage on either end, should trigger a switch to light the Brake Warning light on the dash.
This switch is installed in a small brass manifold that supposed to sit below the brake cylinder on the frame.
Unless all that stuff is removed...as you mentioned it is not stock...
