Lionized
- 6:52 AM
- Mar 23, 2014
- Vancouver Canada
I wanted to revive this thread as I've found my source of low vacuum. I finally got around to doing a compression check and have discovered that I have two/three cylinders which are low:
1= 90psi 2=120
3=140 4=140
5=150 6=132
7=145 8=145
Now, I'm really hoping some of you more experienced guys will chime in here. What I plan to do is get the engine up to temp and drizzle some water through the carburetor to break up any carbon deposits. I've also considered, and have prepared, a gallon jug of distilled water to take on a highway blast at around 60mph. Connecting a 6' 1/4" vacuum line to my manifold vacuum port and running through that until it's dry. I'm fairly certain it's carbon deposits and the rings are more than likely gummed up. There has been very little freeway driving done with this car...as it's never really been running properly. It's real, REAL close though.
Short of a ring job, anyone else have ideas?
1= 90psi 2=120
3=140 4=140
5=150 6=132
7=145 8=145
