Manual disc brake master cylinder
Beekeeper
It’s a disease without a cure!
1:59 AM
Rogersville,TN.
which 4 bolt master cylinder do I need for manual disc brakes on a 69'
Coronet?
What bore size are most guys using? I see a 1" and 1.125". Mine originally had drums and I am changing to
mopar single piston calipers.
Kern dog,
Thanks for the info on the master cylinder
jegs carries a 15/16" bore master cylinder from right stuff for 65 dollars. Works well.
I'm planning to use the 73' up A body single piston calipers. Anyone used the 73' up disc/drum master cylinder with the factory manual push rod? Was wanting to 1" or smaller bore for less pedal effort
