FOR SALE Manual Steering Gear Box!
69 Charger 500 Fanatic
1:32 AM
Louisville, KY
Feedback: +1 / =0 / -0
Two manual steering boxes.
$75.00 each + shipping.
Thanks for the ad space!!!
You will need the correct pitman arm.....although on some cars, the manual and the power steering arm are the same but cannot remember which?? The parts stores can tell you if there is a difference between the two arms for that model.
And you will need to either swap out the steering column to the longer shaft or buy an adapter to make up the difference in length of your current steering column shaft and the distance to the manual gear box. The adapters are the easier way to go but not necessarily any cheaper than swapping columns.
Got the box today 4-23. Thanks 69 charger 500 fanatic!
Sebring+
