Master Disconect
Kevsdodge66
New Member
1:16 PM
Michigan
Question is I have installed a master electrical disconnect switch on my Coronet. How do I wire the system so that when the switch is thrown and the motor is running every thing is shut down?
You put the switch between the battery and everything else.
If you have a Mopar alternator ,you may have to wire in a relay to shut off the charging system to stop the engine.
