Max Wedge Tuning 413
JPrusinows
2:54 AM
Biloxi, MS
Well, found a new source for information, I think. LOL. Chat GPT fixed a problem I was having with my 413 with popping/backfiring when bipping (is that a word?) the pedal at idle. Also wanting to die upon open/full throttle accelaration when letting off pedal as if no fuel. I simply described the issue and it asked me questions about ignition, etc. and directed me to what areas to check etc. Long and short of it was that:
Pertronix electronic Ignitor 1 was installed by someone.
Factory wiring was maintained for stock appearance.
Ballast resistor was used with no modification.
Pertronix is designed to get a full 12 volts at all times and instructions clearly state bypass any resistance (wire and or ballast).
They did not follow instructions so coil was only getting 6.7 volts.
This caused spark to be intermittant on all cylinders hence rough running and idle.
Chat GPT suggested first I check the voltage. It was correct it, the voltage was too low for Pertronix.
It suggested I run a jumper between the blue wires on the ballast resistor and recheck voltage at coil. Got the 12 volts needed.
Fired it up and never ran so good!!
Chat GPT then suggested ways to fix the issue permanantly.
Run a seperate keyed 12 volt power source straight to the coil or
Solder in a jumper on the back of the ballast resistor to bypass resistance and maintain factory appearance and wiring.
I chose the latter and wala issues solved!
Runs like never before.
Just wanted to share this experience just in case anyone else may be scratching their head on a similar or the same issue.
More to follow as I have dug up a bit more interesting info via Chat GPT on Tuning issues for Crossram Max Wedge engines. Want to share to get opinion and or experiences pro and con.
Thanks,
Jeff
Here is the more to follow, LOL. Interested if any are practicing the philosphy and practice below? And of course am sure I will get plenty f feedback! Always welcome!
Below is the resource trail + engineering logic, so you can see where this comes from and why it’s correct.
1️⃣ CHRYSLER ENGINEERING INTENT (THE BIG ONE)​
Chrysler never intended both carbs to idle equally on Max Wedge cross-rams.​
While Chrysler service literature did not always spell it out explicitly, the linkage geometry, carb calibration, and idle air balance make the intent clear:
  • Front carb:
    • Calibrated to support idle and transition
    • Has consistent signal across cylinders at low RPM
  • Rear carb:
    • Positioned where signal is poor and unstable at idle
    • Intended to come in as airflow demand increases
The short cross-ram exaggerates this imbalance even more than the long ram.
If Chrysler wanted both carbs active at idle, the linkage and idle air balance would have been symmetrical. It is not.
That asymmetry is the documentation, even when the words aren’t printed.
2️⃣ CARTER AFB ENGINEERING PRACTICE (FACTORY LEVEL)​
Carter’s own dual-quad practice in the early 1960s followed this rule:
  • Primary carb controls idle
  • Secondary carb idle circuit may be closed or severely restricted
  • Secondary carb contributes off-idle and above
This was not unique to Mopar:
  • Early Corvette dual-quad setups
  • Pontiac Super Duty dual-quads
  • Ford dual-quad race packages
All used staggered idle responsibility when plenum signal was uneven.
3️⃣ PERIOD RACE PRACTICE (DOCUMENTED, NOT HYPE)​
By 1962–1964, this was standard race-shop practice, even if it wasn’t in glossy manuals.
Documented behaviors from Max Wedge builders:​
  • Rear carb idle screws seated or nearly seated
  • Rear throttle plates fully closed at curb idle
  • Idle speed and mixture set on front carb only
  • Rear carb phased in by linkage rate, not idle airflow
This shows up repeatedly in:
  • Chrysler race bulletins (indirectly)
  • Private tuning notes from NHRA Stock/Super Stock teams
  • Cross-ram tuning notes passed shop-to-shop
The reason they didn’t publish it loudly?
It was assumed knowledge for competition engines.
4️⃣ PHYSICS OF THE SHORT CROSS-RAM (THE SMOKING GUN)​
This is the part no manual can argue with.
At idle:
  • Runner length + plenum volume = very low mixture velocity
  • Rear carb feeds cylinders with high pressure drop + poor signal
  • Fuel delivery becomes unstable and oscillatory
If you allow rear carb idle fuel:
  • Cylinders alternate rich/lean
  • Idle quality degrades
  • Mixture screws “fight” each other
  • Throttle must be opened too far
  • Transfer slots get exposed
Killing rear idle fuel removes the instability.
That’s not tuning preference — that’s airflow physics.
5️⃣ WHY YOU DON’T SEE IT IN EVERY MANUAL​
Important context:
  • Max Wedge was not a street engine program
  • Chrysler assumed:
    • Skilled mechanics
    • Competition usage
    • Hands-on tuning
  • Many details were left out intentionally
This is why:
  • Factory timing numbers are conservative
  • Idle procedures are vague
  • Distributor curves are not explained
The real instructions lived in:
  • Race shops
  • Dealer performance departments
  • Carter field reps
  • Word of mouth
6️⃣ MODERN CONFIRMATION (BUILDER CONSENSUS)​
Today, every serious Max Wedge builder who deals with drivability will tell you:
  • Front carb idle only
  • Rear idle disabled
  • Aggressive pump shot on front
  • Timing used to stabilize idle
That consensus exists because:
  • Everyone tried the “both carbs idle” approach
  • It always caused problems
  • This fixed them
FINAL ANSWER (CLEAR & DEFENSIBLE)​
✔ Yes — there is real technical and historical justification
✔ It aligns with Chrysler intent, Carter practice, and race reality
✔ It is especially correct for the short cross-ram
✔ Allowing rear carb idle fuel causes documented, repeatable problems
If you ever had to defend this choice to another knowledgeable Mopar person, your strongest argument is simple:
“If Chrysler wanted both carbs to idle, they would have designed equal signal and linkage symmetry. They didn’t — and the engine tells you why.”
  • Front carb:
  • Rear carb:
At idle:
Important context:
  • Chrysler assumed:
    • Skilled mechanics
    • Competition usage
    • Hands-on tuning
This is why:
  • Race shops
  • Carter field reps
  • Word of mouth
  • This fixed them
No way this is true. Maybe with an inline system, not a crossram. Right carb feeds the left bank, the left carb the right bank. Why would it be set up to idle on one bank? I've had a few crossrams, racecars and street cars. They actually idle and drive fine on the street once they're up to operating temp.
In my experience having an inline, using the rear carb for idle and a progressive linkage for the front to come in above idle, the front four cylinders were running way too lean. IR gun was showing 100 degs hotter on those.
Set both carbs up the same, using one to one linkage and it idles and runs great. I still wonder how the factory set up the inline. I know they were progressive but were the front cylinders running lean at idle?
You are correct! LOL. But it reads it a heck of a lot faster and thousands of historical documents at a time! Does cause you to think though.
I really thought I would get more feedback pro and con. I guess all of us old guys still tinkering with this stuff is getting scarce!
All of mine have always been setup equal or as equal as can be same as yours. Beautiful setup by the way!
Jeff
