terrywalker
- 1:06 PM
- Apr 14, 2017
- Kennewick, Washington
On my 1974 Charger 360 with Thermoquad carb. I installed a new stock mechanical fuel pump in April of this year, bought from a local parts store, after the previous new pump failed to pump. Ran the car several times using non-ethanol gas with the new pump. I went to start the engine today and no fuel. I have a hose hooked to the suction of the fuel pump and gas in a clear container so I could see if the fuel level went down as I cranked the engine. Failed. I put a funnel in the end of the hose and poured gas directly into suction of pump. Gas stayed in funnel during cranking. This is the second fuel pump this year. What are you guys using for mechanical fuel pumps now? Apparently the ones from Autozone don't hold up. Suggestions?
Terry W.
Terry W.
