FOR SALE Milodon Big block gear drive
65coronetAFX
6:06 AM
Boise
Feedback: +1 / =0 / -0
I have a nice Milodon # 13250 Big block gear drive for sale
All gears seem to be in really good shape top gear has the cam thrust button
It has made roughly 30 1/4 mile passes and very minimal street driving (maybe 300 miles )
This needs a more offset outward damper or a spacer on a stock height damper or blower drive hub
I ran with a damper and spacer
Haven’t ran it in quite awhile and decided I probably won’t use it so I figured I would sell it to someone that will
$ 550 or make offer Thanks Matt
Pm me here please I will get back to you .
that appears to be a 13250 unit, the difference is the crank outlet area on the 13000 is machined down for damper clerance,those 3 small holes r the tell for blown app. without that machining done u would have to use appx .200 worth of spacers to get the damper pressed on all the way to the crank gear which throws all all drive belt accs like alternator, etc with the damper sticking out......
Stage 3 ,
You are absolutely correct about this , my mistake and I did run a spacer on my damper but with a 3/8 motor plate
And a thin spacer on my lower pulley
My alternator mounts to my motor plate and a electric water pump
I changed the ad and thank you for noticing cuz I forgot about that
