SOLD Mopar 2 groove Performance Billet Crankshaft Pulley
ibsorgn
12:07 PM
Somerset, KY.
Feedback: +0 / =0 / -0
This is a Aluminum Billet double groove Crankshaft Pulley for Mopar V8 Engines. This pulley was pulled from my BB stroker motor but will fit small blocks. I have included close up pictures of mounting measurements. This pulley was designed for use with stock power steering and alternator brackets. Number of Grooves: 2, Diameter: 5.2", Overall Length: 3.2", Bolt Pattern: 6 Bolt
Would like to have $39 plus shipping (your choice)
will it fit just a street 440 with a 871 blower ?..
It was pulled from my 440. If the blower crank cog uses an adapter for a 440 bolt pattern or bolts straight through then I see no reason why it wouldn't fit. Measure the setup and compare it against my measurements so to eliminate doubts.
Hi any part numbers on that pulley? Were you running that on a Fluidampr balancer with a flat face?
Thanks,
Steve
Sorry Steve I sold the pulley last night but to your question, no part number and it was installed on an aftermarket neutral balanced flat faced balancer
