moparbob75
has anybody used part # P4452783 mopar 458 cam in their 383? Im thinking about puttin one in my 383. i want to make it run like an HP motor would do. is it a good cam to use for a stock acting 383 HP?
the 272-.455 cam runs surprisingly well.
the one i have in a 9.3:1 compression 440 has very good low and mid rpm. when i had the 6-pak on the engine it was a 5200-5400rpm max. with a stock 4bbl, maybe 5000rpm; gobs of torque. a 383 will be 200-300rpm higher. the .455 lift is about right for unmodified heads and exhaust.How does it run as a street cam; low speed, off-idle & part throttle. Is it a full-throttle high rpm-type camshaft in the 383, or does it have good street manners?
