SOLD Mopar P452993AE 'Purple' Cam & Lifters Kit
TorRed
9:59 AM
The Villages, Florida
Feedback: +1 / =0 / -0
Mopar P452993AE 'Purple' Cam & Lifters Kit, Very slight surface rust on the two outer lobes, should clean up fine, cam shipping box and small lifter boxes show their age but everything looks great otherwise.
Cam specs are:
Brand:
Mopar Performance
Manufacturer's Part Number:
P4452993AE
Part Type:
Camshaft Kits
Product Line:
Mopar Performance Purple Camshaft Kits
Cam Style:
Hydraulic flat tappet
Basic Operating RPM Range:
2,000-6,000
Intake Duration at 050 inch Lift:
238
Exhaust Duration at 050 inch Lift:
238
238 int./238 exh.
Advertised Intake Duration:
280
Advertised Exhaust Duration:
280
Advertised Duration:
280 int./280 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:
0.474 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:
0.474 in.
0.474 int./0.474 exh.
Lobe Separation (degrees):
110
Camshaft Gear Attachment:
1-bolt
Computer-Controlled Compatible:
No
Lifters Included:
Yes
Lifter Style:
$350 Shipped In The U.S.
More pics. Looks like what I thought was rust was mostly the purple grease the cam was coated in. After cleaning it off it still has a few slight blemishs that may still be grease or like I said an actual blemish. Not sure what these looked like from the factory, etc.. so please judge for yourself.
