1969 beep beep
Mopar Parts for sale. Send me a pm or an email to [email protected]
I am located in Canada and shipping will be extra.
1. UltraSonic Digital Thickness Meter used once for checking block $150
2. Edelbrock 383 Torker Intake Used $150
3. Moroso Blue Max Universal Wires Used $20
4. Moog K7103 Off Set Bushings New $30 for a set
5. Mister Gasket 2975 Fuel Psi Gauge Adapter New $5
6. Powder Coated Alternator 2 Groove Pulley-slight bend in pulley hub from puller, pulley still good used $15
7. Powder Coated Water Pump Pulley 2 Groove Used $15
8. Powder Coated Torsion Bars BBody 440 & Hemi Bars, slight bend in bars Used $25
9. 440 Source Usa Cylinder Head Bolts Big Block Used $40
10. Holley Carb Chrysler Throttle Bracket 20-7 New $5
11. Battery Cable Clamps New $2
12. Moroso Solid Mounts Big Block 62520 New $25
13. 18 ½ inch Flex Fan Used $5
14. 18 inch Gm Fan Used $20
15. 5/16 Fuel Sending Unit for 69 RR Used and Works $40
16. Cloyes Timing Chain 2800 miles on chain 9-134 $20
17. Energy Transmission Poly Mount 5.1112G for A833 Tranny Used $ 20
18. Mopar Valve Cover Bolts for Cast Valve Covers P500-7053 New $20
19. 1969 Exhaust Manifold Studs, Nuts and 3 Long Nuts Used $25
20. Schumacher Engine Shims Kit New $20
21. 383/440 Bell Housing Clutch Fork Boot small rip in boot Used $5
22. Bell Housing Clutch Fork for various applications removed from 69 B Body Used $30
23. Carter AVS Carb Rebuilt Kit New $20
24. 69 B Body Horn Relay from Roadrunner Used $5
25. 66-69 B Body Hose Clamps Non A/c New $10
26. 69 Roadrunner Interior Dome Light Lens $2
27. Stage 8 Locking Nuts when using exhaust studs in cylinder heads 8998 New $20
28. –Qty 3- Mopar Voltage Regulator P3690732 Used $15 each
29. Mopar P4349620 Hold Down Washers For Steel Valve Covers New $5
30. Mopar 23 Spline Throw Out Bearing Assembly 1-New $30, 2 –Used $20
31. –Qty 5- 13/16 left hand lug nuts $5
32. –Qty 2- Mopar Performance Valve Cover Oil Fill caps Push and Turn New $5 each
33. Mopar 3751827 water pump 8 blades Used $5
34. Modified Oil Pick up Tube Used on Hemi 6 Quart pan $5
35. Mancini Racing MRE224 Square Style Oring for rear main seal $3
36. B Body Hood Springs from a 69 RR Used $25
37. Alpine CDA 9883 Cd player Like New $35
38. 1969 Road Runner Front & Rear Interior Arm Rest Bases Oem Used, Chrome is peeling $20
39. Mopar P4452987 Rear Spring Shackle Bushing New $10
40. 16 Gauge Fusible Link Wire Roll $5
