SOLD Mopar Power Window Relay (Upgraded Version)
A383Wing
7:41 AM
Somewhere
Feedback: +2 / =0 / -0
(updated version)​
Now available for your Mopar is an updated version of the power window motor relay under the dash. The original style relays are getting harder & harder to find, and if you find them, you have no idea if they are good or not. What I offer you is a “Plug-N-Play” system upgrade. No cutting or splicing of your under dash harness in your car. Basically, all that needs to be done is to remove the OE style relay, mount the newer Bosch style relay in place, and connect the special adapter harness from the new relay to your cars harness. It’s that simple. Here is what’s included in kit: One of the Bosch style relays, (30a-40a rating for relay), one special adapter harness, mounting ground screw, and installation instructions.
Shipping price to lower 48 States is free. If you are outside the U.S., shipping will be determined by your address.
There are 2 types of relays for these cars, a 3 pin style that uses the metal body of the case to complete the ground circuit, and the 4 pin style that uses the 4th pin for ground connection. You must specify how many pins are on your OE relay so I can send you the correct style to fit your car.
$30 with free mailing to lower 48 States from Auburn, Washington....out of country shipping determined by your address.
Bryan (PM me here if you have any questions)
Will have to check mine the next time I get home. Are they for any mopar that has the power windows?
yes, most any Mopar from 68 on up will have a relay.....it will be a 3 pin or a 4 pin style
I have these in stock here all the time....if you need one, contact me
Thanks for your interest
Bryan
