SOLD Mopar vintage dana 60 original 1968
D69Charger
12:53 PM
Mid America
Mopar Vintage Dana 60 Original 1968 Build date 05-27-1968 Power lock Track Pack Unit, 513 Gear Ratio, plastic Dana Green plug, backing plates with 11 inch finned Brake Drums, measures B Body 54 ½ inches flange to flange, spring perches moved inboard for larger tire clearance.
This Dana was under a 1969 Dart same as in the 1968 Hemi Darts which all ran the Mopar B Body Dana 60.
Cleaned up the axle tubes but I left the markings on the third member.
South Bend IN. 46619
$1650.00
$1650.00
I'm looking for a Dana 60 for the street for my 69 Coronet. I'm not that familiar with the "track pack" and the high gear ratio. Can you explain a little more about it? Thanks!
Don't think 5:13 is factory, 4:10,3:91, 3:73,3:55s ?? Good Buy!!!! Just the same
Mikedonz, I have a better suited for the street Dana 60 with 4:10 gears for B Body if your interested, thanks.
